Noisy Driver's window
Old Apr 2, 2004 | 06:33 AM
wgm114's Avatar
wgm114
When I put my driver's window up or down, it makes a terrible screeching noise. Been to the dealer three times and they have yet to fix it. Any clues from you Master Ford technicians? Thanks.
Old Apr 2, 2004 | 09:30 AM
propellerhead's Avatar
propellerhead
I heard a terrible screeching noise when I closed the rear passenger door. Then I realized my kid had his hand in the doorway.
Just kidding.... moving on.
Old Apr 2, 2004 | 09:37 AM
buzzard's Avatar
buzzard
Tough call if the dealership can't even fix it. Does it make the noises when they have it?
Sounds like the alignment is a little off or possibly the motor is wearing out. Why don't you remove the door panel and take a closer look? Maybe you'll be able to see something more revealing this way.
Old Apr 2, 2004 | 09:57 AM
wgm114's Avatar
wgm114
The Expedition is only 2 weeks old! 2004.
Old Apr 2, 2004 | 03:32 PM
mogulskr's Avatar
mogulskr
I was hearing a lot of wind noise from my drivers side window and it had been to the dealer 3 times for new latch, seals and then they basically pushed the top of the doors in to crush the seal. Still no luck. Anyway then the window started to squeal when being raised. So in it went to a different dealer and they said the lubed the window and now the window is squeal free and the wind noise is completely gone. I have no idea how they lubed the window though.
