98 Explorer Turn Signal/Flasher Problem
Old 04-01-2004, 08:40 PM
vhatridge's Avatar
vhatridge
vhatridge is offline
I recently removed my instrument cluster to diagnose a problem with my fuel gauge. When I replaced it, the right turn signal would not work at all. When I turned on the emergency flashers, only the left side flashed - RF and RR were totally dead. After playing around with fuses, everything started to work perfectly. A few days later, the right side is totally dead. Bulbs are all fine. Multifunction switch was replaced about a year ago for other reasons.
Old 08-30-2004, 07:34 PM
Fastkurve's Avatar
Fastkurve
Fastkurve is offline
Did you fix your problem finally ? I am asking because I have problems with my 98 Explorer (flasher and 4 ways do not work) .
Let me know what wqas your fix
Thanks
FAstkurve
Old 08-30-2004, 09:20 PM
vhatridge's Avatar
vhatridge
I haven't determined what causes it, but I can fix the problem by adjusting the steering column angle. Go figure!
Old 09-02-2004, 11:54 AM
1081's Avatar
1081
1081 is offline
I would back track on what you did with the I.cluster. Maybe not take it all of the way out, but I would guess you have either a loose or shorted wire. This may have happened when you had to move the wheel down and wires around to get to the cluster. It may just be something loose since it works when you tilt the wheel. You may even want to start at or around the ignitions switch and connectors. Just some thoughts.
HVACTOM
02-14-2015 04:33 PM
compwrench
1997 - 2003 F150
06-25-2012 04:45 PM
busakiller2001
38
11-12-2010 11:50 AM
aerocolorado
Aerostar
22
02-10-2009 03:57 PM
hartmark
Electrical Systems/Wiring
06-03-2003 10:13 PM
Quick Reply: 98 Explorer Turn Signal/Flasher Problem
