yo i took my compression test on my 352 a few weeks ago and here were the results.
1-95
2-100
3-100
4-93
5-90
6-95
7-93
8-95
is that any good? its supposedly got 53 thousand on it and i just had my heads rebuilt.
i unfortanely didnt take a comperssion test before i had my heads done.
i added oil to every cylinder like the book said and they went up by 5-10 psi for every cylinder which means im leaking comperssion though the rings i guess. what should the compersion be on a 66 352?
You'll be OK as as they stay as they are...within 10% from the highest cylinder to the lowest and they are..But Scroob said you do need to retorque the heads- Russ
