Sponsored by: Real Truck
kluncking sound
Old Mar 31, 2004 | 09:56 PM
takerevo's Avatar
takerevo
manunal shifting problems & front end noise
Need some help. I have a 2002 f-250 with manunal transmission. when shifting to 2 gear it makes a kluncking sound. also when i'am backing up and i push in the clutch it also makes this sound. i also have a noise in the front end. when i go over a bump it sounds like something is rubbing. any one have any ideas on what it could be? thanks
Old Apr 1, 2004 | 09:53 AM
Big Orn's Avatar
Big Orn
The "clunk" could be the rear driveline yoke. If so, remove the driveline (be sure to mark it's location) and install some teflon grease in the yoke. You can do a search on "clunk" here in the Super Duty forum and get more details.
The noise up front could be the spring hangers/bushings or the track bar is loose.
Old Apr 1, 2004 | 09:54 AM
78fordman's Avatar
78fordman
Most likly rear u-joint, check the carrier bearing if equiped.
Old Apr 1, 2004 | 08:53 PM
takerevo's Avatar
takerevo
thanks for the help
