Sponsored by: Auxito
grinding noise
Old Mar 31, 2004 | 05:56 PM
98150's Avatar
98150
grinding noise
on my 98 150 i have a growling noise when i make right turns can somebody give me an idea where to start
Old Mar 31, 2004 | 06:27 PM
Racerguy's Avatar
Racerguy
Hi 98150 and welcome
Is your truck 4x4 or 4x2?
Does the noise sound like front or back?
How fast are you going when it makes the noise?
Old Mar 31, 2004 | 07:38 PM
97_Ford_Lariat's Avatar
97_Ford_Lariat
The growling noise that you have when you turn is coming from wheel bearings. Check wheel bearing first. When you lean when you turn and put weight on the wheel bearing that is bad it will growl.
Old Apr 1, 2004 | 10:18 AM
fordmanss12's Avatar
fordmanss12
I'm getting a growling also, a 98 f150 4x4. The noise seems/feels like it's coming from the front left wheel. I only hearing it when I'm braking and almost at a stop, say the last 5-7 feet before stopping. Would this also be a bearing? Brakes seem fine, I had a look at pads and rotors (they were changed 6 months ago)...
Old Apr 3, 2004 | 01:09 PM
98150's Avatar
98150
my truck is a 4x4 and the noise is at low speeds about 25mph and it sound like the front
