C6 Problems, No Reverse, No Neutral
Old Mar 31, 2004 | 12:17 AM
branger's Avatar
branger
I just rebuilt my C6 4x4 tranny myself. I tested it with the rearend up on blocks and went thru the gears(ratchet shifter). I could shift in all gears but reserve did not move and nuetral acted like drive but I still had driveand the 123 gears. Also I realy seems to be pulling the motor down. Lugging it too much. When I rev the motor the rpms drop instantly. Not sure what it could be. If anyone has some hints it would be greatly appreciated. Thaks.
Old Apr 6, 2004 | 12:23 AM
The Tree's Avatar
The Tree
The torque converter probably isn't filled completely with fluid. As for the gears either the valve body is misaligned or thelinkage is messed up. I had to play with my linkage for a while now 2nd is drive and R is park.
Old Apr 17, 2004 | 11:37 AM
garypettengill's Avatar
garypettengill
I had the same problem when I rebuilt My C6. Turns out I had one too many "steels" in the forward clutch pack. With the fwd. pack too tight it wouldn't release for nutural or reverse. Make sure you have the clearence in all your clutch packs that is required.
youngone1234
Sep 3, 2016 04:48 AM
JOD F100
New Member Introductions
May 24, 2016 02:27 PM
william16339
May 17, 2016 07:25 PM
not enoughsmoke
Dec 20, 2010 04:30 PM
Jarniscipus
Sep 24, 2010 11:09 AM
