Sponsored by: Real Truck
Runs rough when warm
Old Mar 31, 2004 | 12:05 AM
BigRed1's Avatar
BigRed1
My '99 SD V10 (4wd,auto, crew cab, short box, Lariat) runs rough when warm. It is smooth when cool, but the longer it runs the worse it gets. I have 45k miles, new fuel filter, clean air filter, and a tank of Gum-Out through it.
It just doesn't seem to have the power it used to have, either, but that is very subjective.
I'll take it to the dealership, but I'd like to get some ideas about what the problem could be before I give myself (and my checkbook) to the dealer's tender mercy.
Any suggestions?
Old Mar 31, 2004 | 02:41 AM
Connect's Avatar
Connect
You got me, maybe the oil or the ignition system is off... If all your fluoids check out and are right temperature... dunno
Old Mar 31, 2004 | 07:48 AM
FortyFords's Avatar
FortyFords
It can be a # of things !
1)cop going bad (coil on plug)
2)could be plugs (might be loose or worn)
3)any # of sensors that control engine idle and fuel trims
4)Iac valve dirty or sticking.
Its not easy to determin without a scanner or manuals to chk voltage ref's
scanning can point to a certain cylinder for misfire
Take it in have them look at
Rich
Old Mar 31, 2004 | 08:32 AM
BigRed1's Avatar
BigRed1
Thanks!
Rich -
Thanks for the list! That is what I was looking for - some suggestions of what to ask the service guys about, so they don't charge right off and do the most expensive thing first.
