65 Ford steering
Old Mar 30, 2004 | 09:34 PM
chucky725's Avatar
chucky725
Question 65 Ford steering
I am the new owner of a 65 Ford Twin I Beam and the steering is very rough. I am sure there is a way to cure this as my arms are wore out. Any help appreciated.
Old Mar 31, 2004 | 05:17 AM
ddavidv's Avatar
ddavidv
Question
Define "rough".
I have a '65 with manual steering and bigger tires, and my impressions are:
1) Once moving, it steers pretty easily
2) The ratio is not very quick, meaning you must wildly flail the wheel to make tight turns
3) Having everthing in the front nicely greased makes a big difference
4) Proper tire inflation, and having some tread on the tires, makes a lot of difference also
If what you are trying to say it that the steering is not smooth through it's arc, you may either have some worn linkage that is binding or a bad steering box.
If you feel it's just too hard to steer and you've done all the maintenance above, then you may be a candidate for a power steering swap. Most guys swear by this upgrade, but I'm not a big fan of the numb feel that goes with it. A matter of personal taste. Plenty of posts on how to do it if you perform a search.
Old Mar 31, 2004 | 11:01 AM
tasdad's Avatar
tasdad
steering
That's the beauty of these trucks-you get to really DRIVE them! I guess if you want power steering, etc. that can be done, but then why don't you get on of these newer "sterile" trucks? Just food for thought.
Old Mar 31, 2004 | 11:20 AM
PROSTOCK's Avatar
PROSTOCK
I personally love driving my 65 F250 daily, but don't like to work up a sweat parking it. Do the pwr steering conversion, its easy, relatively inexpensive and you'll enjoy driving it more!!!! Just another opinion.....
Old Mar 31, 2004 | 02:52 PM
cdherman's Avatar
cdherman
As ddavidv points out, aside from poorly maintained stearing and suspension components, the major culprit with difficult steering is wide tires. The original bias ply tires were relatively narrow and bias ply tires do not "squat" down like radials. So even if you have original rims, or narrow aftermarket, just running radial tires will make turning it harder.
I am running original rims, with 215/75/r15 radials and I find that combo to be reasonable to steer. They sit rather low (I am not into low vehicles, but that makes it about the right height to ease in and out of). I have well maintained steering, from the box to the spindles though.
I think that if you want to run big fat tires, you will have to consider power steering if you are not very big/muscular.
