302-351w swap
Old Mar 30, 2004 | 09:27 PM
351wtruckguy's Avatar
351wtruckguy
302-351w swap
I am currently rebuilding a stroked windsor And will be putting it into my '92 f-150. I would like to know if the wiring harness going to the distributer is nessasry if I install a MSD Distributer with an MSD 6AL Ignition box? IF I do how do you recomend Installing The new distributer if The plugs are not the same from a 5.0-5.8? Any other tips in installing this would be great. Thanks
Old Mar 30, 2004 | 10:24 PM
EPNCSU2006's Avatar
EPNCSU2006
I would get an MSD distributor for a 351 EFI. It has the TFI module, which must be there for the computer to run the engine. You will then install the 6AL between the coil harness and the coil. A local auto parts store will be able to get you the correct plugs.
MSD distributor:
For roller cam: http://store.summitracing.com/partde...art=MSD%2D8452
For non-roller cam: http://store.summitracing.com/partde...art=MSD%2D8453
