I've read most of the threads on the transmission fuild change. I have a 2000 xlt with a v10. When rotating the engine to find the plug on the torque converter which way do you turn the engine? I plan on using a 1/2 ratchet with a pipe extention. clockwise or counter or just start the motor and look at it and go with that?
The x has 53k and I like to change out the fuel filter. I've read the hayes manual and it says to bleed off the fuel pressure at the fuel manifold. It has a tire type valve. Do I need to bleed it of can I loosen the fuel filter and let it bleed off under the truck?
I've had the truck for few weeks and it is awesome. I been lurking these formums for about 4 months. Alot of great advice here. After I get the fuilds all change out and regualar maintance up to date. I like to do the rear sway bar and put some new shocks on.
Thanks Ron Caravona
