1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
V10 high idle rpm
Old 09-21-1999, 08:01 PM
Hubert Badgley
Guest
Posts: n/a
V10 high idle rpm
My V10 is or was idling at about 2000rpm. I took it to the dealer yesterday for this problem and a noisey suspension. When the service manager pulled it in last night it was still idling fast but when the mechanic went to work on it this morning it was idling normal again. It had been doing this for several days before I took it in and I had pulled the plastic cover back on the throttle linkage at the fuel injector to make sure it was returning all the way to the stop which it was.
Has anyone had this problem and if so what was the diagnosis on it.
Thanks,
H. Badgley
99 F250 Lariet,CC,LWB,SRW,V10,4x4,4.30gears
Old 09-22-1999, 05:03 AM
Spence's Avatar
Spence
Spence is offline
V10 high idle rpm
The Idle Air Control valve is sticking, possibly from carbon build up. or just bad all together.
Spence
Old 09-25-1999, 04:41 PM
eugene's Avatar
eugene
eugene is offline
V10 high idle rpm
what kind of noise are you having. i am having a slaping or clunking noise in mine.
Old 09-26-1999, 04:00 PM
hubert's Avatar
hubert
hubert is offline
V10 high idle rpm
The noise I have or had was a groaning noise when ever the suspension moved.There was no slapping or knocking noise.The dealer preformed TSB99-16-3 on it which replaces spring isolators which according to the remarks on the repair sheet did not eliminate all of the noise and they retightened the spring bolts at the shackles.It is a lot better but I have heard some noise a couple of times.
Hubert
Old 10-27-1999, 05:59 AM
Steve's Avatar
Steve
Steve is offline
V10 high idle rpm
>of times.
> Hubert
Old 10-29-1999, 12:09 PM
Randy Pace
Guest
Posts: n/a
V10 high idle rpm
Greasy89
34
07-28-2019 05:48 PM
Dgilling
Modular V10 (6.8l)
16
06-14-2017 08:06 AM
coreymp1992
06-23-2016 07:02 AM
Primetime1
Computer Chips & Tuners
02-28-2016 09:22 AM
Grand Canyon
15
11-25-2006 08:08 PM
Quick Reply: V10 high idle rpm
