Sponsored by: Real Truck
In bumper reverse sensor installation
Old Mar 29, 2004 | 11:18 PM
hang10's Avatar
hang10
I bought a set of reverse sensors that are the type that I have to drill out the bumper to install them. Pretty much like the OEM type. They have to be installed in the bumper. I didn't purchase these throgh a Ford dealer. I am told that since it is a metal bumper, I should coat the holes with a zinc compound after drilling. The set does not come with this. Wondering if it is necessary and exactly what is the compound I should look for. Is it a zinc anti-seize paste, or a liquid? What is the purpose? I would assume it is to keep the holes from forming rust. Or does it have something to do with conductivity? Thanks for any info.
Old Mar 30, 2004 | 07:20 AM
unit5alive's Avatar
unit5alive
Hang10, eastwood co. sells what your looking for!
Old Mar 30, 2004 | 10:14 AM
cwb's Avatar
cwb
I just painted mine with a clear coat. It is so they will not rust, it doesn't have anything to do with conductivity.
Old Mar 30, 2004 | 11:44 AM
hang10's Avatar
hang10
Thanks. I didn't mean conductivity in the electrical sence of the word. I meant reflectivity/sensitivity of the sensors. Where did you run your wiring into the cab? Did you go all the way under and up through the engine compartment, or were you able to find a drain hole in the floor pan somewhere?
Old Mar 30, 2004 | 03:50 PM
cwb's Avatar
cwb
I already had the sensors but I cut some lights into my bumper and ran the wire up into the engine comp. and through the clutch hole.
Old Mar 30, 2004 | 04:11 PM
fireman28's Avatar
fireman28
Hang10,
Let us know how it works.
