rough idle info
Old Mar 29, 2004 | 10:52 PM
Uncle Jim's Avatar
Uncle Jim
rough idle info
Had an intermitent rough idle. Ford mach said bad 2 piece flywheel. Later noticed a small fuel leak. Had that fixed by an independent(lucked up, used to work for ford teaching mach's how to work on them) and when I told him about the idle, he said it's probably the fuel leak and that was all that it was. Just some info that may help someone.
Old Mar 29, 2004 | 11:07 PM
kitsapcountychopper's Avatar
kitsapcountychopper
i had a ruff idle problem also found a bent push rod ,hope you are more luck
xlt4wd90
Jan 9, 2010 02:50 AM
optikal illushun
Ford vs The Competition
64
Apr 12, 2006 02:51 AM
MyChewToy
Oct 13, 2004 01:57 PM
Joe
Jan 9, 2002 01:01 AM
snekrs_mach1
Mar 30, 2001 01:35 PM
