Bronco II Ford Bronco II
Engine rebuild
Old Mar 29, 2004 | 09:01 PM
chadscanadian's Avatar
chadscanadian
Engine rebuild
Hi, i have an 84 bronco2 2.8l 4x4. I need a new engine soon, mine has 550,000 kms on it. I have helped with engine installs and pulls before but, i dont know what i should get all new like headers rad and that crap. I wonder if i should put a new oil pump and water pump and all that in or use the old stuff any advice.
Old Jun 23, 2004 | 03:57 PM
'87BroncoII's Avatar
'87BroncoII
yes
REPLACE EVERYTHING that you can afford to the more the better i just finished rebuilding my 87 bII engine and i put premium everything in it new oil pump, new pistons ,connecting rods, rod and main bearings, cam, lifters, all new gaskets, had complete valve job i probabally spent $1500 on it it is well worth it cause after the hassle of doing it once you wont want to do it again for a while
