Flat Towing
Old Sep 10, 2004 | 01:38 AM
rebocardo's Avatar
rebocardo
Just thought I would throw in about the tow dolly. I did two cars today with one. I tell you, they really mean it when they say not to back one up, even if it is possible to do it straight. Going down a very steep hill with a long incline with a Ford Taurus on the back made me glad it was a 35 mph zone with no cross streets. The worse thing is you do not have trailer brakes to straighten it out. I think cross country I would get a good car carrier even if I rented it from U-Haul. Though from their site, it appears they only have surge brakes.
U-haul tried that scam thing with the plug adapter someone mentioned earlier, so I rented from some place else.
Old Sep 10, 2004 | 06:45 AM
jowilker's Avatar
jowilker
John Did you keep the truck in a lower gear going down the hill? That works well also.
John
Old Sep 10, 2004 | 12:11 PM
rebocardo's Avatar
rebocardo
Yes, I kept it in second going up and down the biggest hill (actually 3rd on the NP435) so I never hit above 40 mph going downhill. Granny first is wonderful for starting off on hills at stoplights. The wornout 390 still has enough torque to spin the tires at launch, only did that once before I got the hang of it.
I think the tow dolly having a wider track then the rear axle of the truck does not help much going downhill.
Old Sep 10, 2004 | 01:21 PM
Daryl Hunter's Avatar
Daryl Hunter
Towing using a full trailer is the only way to go. You can then use the brakes trailer to slow you down in addition to the truck's brakes.
Old Sep 10, 2004 | 02:16 PM
Eric C.'s Avatar
Eric C.
I used to work at U-Haul and all the Auto Transports have surge brakes. The will not rent one to you unless you have a receiver hitch unless you go to a dealer and not the center. Tow dollies have a twisting bed plate that allows them to turn tighter. The wider wheel base helps stability. I would trailer the Bronco and use the AT (SAFER)
Old Sep 15, 2004 | 11:29 PM
jbminyard's Avatar
jbminyard
Extra weight?
Do y'all recommend adding extra weight to the back of the bed of a pickup when towing with a tow bar?
Thanks
Old Sep 16, 2004 | 05:45 PM
mikebon08's Avatar
mikebon08
Depends on what you're towing and how much it weighs. If I'm pulling my '82 Lincoln (not an unusual occurrence) I like to put some weight in the back of my truck, but not too much because your brakes have to stop it all too. I've done it without too and can't say I really noticed much difference. About the only time I can think of when it would make a real difference is on a rough road where the two vehicles are bouncing in different directions. If the vehicle you're pulling has a really loose front end and might start wandering, it might help, but in that case I really prefer not to use a towbar anyway.
Old Sep 16, 2004 | 07:53 PM
jbminyard's Avatar
jbminyard
Any recommendations on types of backup chains and best ways to utilize them when towbarring? I assume steering wheel locking should be prevented on towed vehicle as well?
Thanks so much again.
Old Sep 17, 2004 | 12:15 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Yeah you definitely don't want the steering wheel turning and locking. Just leave the key in it .
Old Sep 17, 2004 | 01:22 PM
Eric C.'s Avatar
Eric C.
I pulled my Bronco II from Minnisota to Colorado behind a Dodge 2500 due to work on a tow bar but that was due to not being able to get a tow dolly or trailer to rent in time. It can be done just make sure the towing is heavier than the tow and be sure and keep your speed down. If it starts to get loose be ready to slow down and be carefull. Safety chains attach from frame to frame and try to get them to cross under the bar wether it's a tow bar, dolly, or full trailer You have to have enough slack in the chain to allow for turning but not so much as to drag.
RSCHAP1
All Things Towing
Jul 5, 2016 07:51 AM
ghostshark
1978 - 1996 Big Bronco
Oct 5, 2015 04:53 PM
Thunderhorn
21
Sep 15, 2015 11:34 PM
LipschitzWrath
17
Apr 7, 2015 07:08 PM
XolieX
2004 - 2008 F150
17
Mar 24, 2008 09:44 AM
