ball joints?
Old Mar 29, 2004 | 07:17 PM
Quackhead94ranger's Avatar
Quackhead94ranger
ball joints?
we have a 94 ford explorer 4.0 4x4 pretty sure it ahs bad ball joints, really loud when we go over bumps, almost sounds like the shocks? but i dont know for sure would like your opinions! thanks!
quackhead
Old Mar 29, 2004 | 11:04 PM
mrshorty's Avatar
mrshorty
I would blame radius arm bushings before ball joints if it's clunking when going over bumps. They have a history of failure. You would have to get underneath and check them out, before deciding for sure.
Old Mar 30, 2004 | 06:56 AM
Opera House Works's Avatar
Opera House Works
Yes, check the one under the drivers seat. The heat from the cat causes it to go bad. Be sure to get polyurathane ones because you have likely taken chunks of metal out of your crossmember by now. This is what I call a "big tool" job.
Old Mar 30, 2004 | 01:46 PM
Quackhead94ranger
ahh thank you! i wil have to take a look at it, is it hard to find?
Old Mar 30, 2004 | 05:55 PM
mrshorty's Avatar
mrshorty
Not hard. If you don't have one, I'd suggest getting a repair manual to refer to (If print manuals are too old fashioned for you, www.autozone.com has an electronic version of Chiltons). We'll try to help you with whatever, but it can take so much longer to get answers from a forum like this. It only takes a couple minutes to post a question and who knows how long (hours) to get a response. It will only take a few minutes to look something up in a manual, and then you have the answer right there.
Old Apr 6, 2004 | 08:52 AM
Jet Lizard's Avatar
Jet Lizard
How to check ball joints. Jack up the front wheel, then try to rock the wheel. Pull the upper end of the wheel, and push the lower one -- and vice versa.
If you can move the wheel, ball joints are gone bad. If you cannot sense ony clearance while rocking the wheel, it's probably not ball joints.
And be careful while changing ball joints: do disconnect front ABS sensors' terminals if you don't want get them damaged!
With best regards,
Yuri
Old Apr 6, 2004 | 09:42 AM
Quackhead94ranger
thanks for the help but my parents just decided to waste there money and take it in and someone fix it for us, oh well it's there car there money!!! quack
thanks
