Rear speaker wiring
Radio:
(Click Here For Diagram #1(Radio) & #2(Speakers))
Black Wire - Ground
Black With White Stripe Wire - Right Rear Speaker
Light Blue With Red Stripe Wire - From Light Switch To Radio (light) (Headlights)
Light Green With Yellow Stripe Wire - Hot At All Times To Radio
Orange With Black Stripe Wire - From Light Switch To Radio (Light) (Parking)
Orange With Red Stripe Wire - Right Rear Speaker
Red Wire - To Ground With Black Wire
Yellow With Black Stripe Wire - Hot In Accessory Or Run To Radio
(With Convenience Power Group)
Dark Green With Orange Stripe Wire - Right Door Speaker
Light Blue With White Stripe Wire - Left Door Speaker
Orange With Light Green Stripe Wire - Left Door Speaker
White With Light Green Stripe Wire - Right Door Speaker
(Without Convenience Power Group)
Light Blue With White Stripe Wire - To Dark Green With Orange Stripe Wire To Left Door Speaker
Orange With Light Green Stripe Wire - To White With Light Green Wire To Left Door Speaker
Pink With Light Green Stripe Wire - Left Rear Speaker
Tan With Yellow Stripe Wire - Left Rear Speaker
But should there already be wires behind the seat? Because i can't find them. So how should i go about wiring this up?
Pin Circuit Circuit function
1 19 (LB/RD) Power, Hot with Headlamps on
1000 (RD/BK) Voltage supplied in Start (overload protected) 3
2 57 (BK) Ground
4 – not used
5 802 (OG/RD) Speaker, right rear (18808) +
6 803 (BN/PK) Speaker, right rear (18808) -
7 805 (WH/LG) Speaker, right front (18808) +
8 811 (DG/OG) Speaker, right front (18808) -
797 (LG/VT) Voltage supplied at all times (overload protected) 9
137 (YE/BK) Voltage in Run or Accessory (overload protected) 10
11 694 (BK/LG) audio ground
12 800 (GY/LB) Speaker, left rear (18808) +
13 801 (TN/YE) Speaker, left rear (18808) -
14 804 (OG/LG) Speaker, left front (18808) +
15 813 (LB/WH) Speaker, left front (18808) -
16 694 (BK/LG) audio ground
1 172 (LB/RD) Radio (18806), output, Subwoofer -
4 829 (WH/VT) Remote
3 819 (LG/WH) Radio (18806), output, Speaker, left front (18808) -
6 816 (LG/VT) Radio (18806), output, Speaker, right front (18808) +
5 820 (DB/YE) Radio (18806), output, Speaker, left front (18808) +
8 – not used
7 815 (LG/OG) Radio (18806), output, Speaker, right front (18808) -
2 169 (LG/BK) Radio (18806), output, Subwoofer +
C290c
18A919
1 57 (BK) Ground - Shield
