A restrictive housing will effect airflow, but not filtration. The filtration is 99.9% because of the filter, not the housing.
Exactly! But the original question leans towards airflow and/or performance. So at least we both agree that the K&N with it's less restrictive setup flows better. The benefit here is a quality re-usable filter...
That reminds me. K&N now offers a PreCharger for most of it's popular filters.
What is a K&N PreCharger?
The K&N PreCharger is a specially designed filter wrap made to extend the service interval of your K&N Filtercharger when used in very dusty conditions. They are made from durable polyester material containing a uniform weave. The PreCharger will stop small dirt particles with minimal restriction to the airflow of the filter. The PreCharger is designed to be run dry and can be cleaned with K&N Filter Cleaner. The PreCharger is custom made to fit each application. Double stitched elastic openings assure that the PreCharger will stay in place. The PreChargers are available in a variety of colors, all with a silk-screened K&N PreCharger logo.
Instead of buying a K&N filter, and a K&N precharger (another filter), why not just use the OEM paper filter,
that is known to filter well???? Novel idea, eh?????
I have K&Ns on all my other vehicles. They are normally aspirated engines and airflow at the intake has more of an effect than on a turbocharged engine. The stock filter on the 6.0 is a very serviceable filter for its duty. I for one will stick with the stock until someone can show me independent information that any other filter will give the same or better filtration with same or better airflow.
Well, NO filter will flow even better and filter only slightly less than a K&N.
That is a novel idea. What about less power due to the restrictive housing? How you going to explain that???
If you use the K&N filter/Generation II FIPK kit and the precharger...you'd get excellent filtration and better flow...Right??? Plus a filter that will service the 6.0L engine for life. Na...don't want that...lets pay $90-100 every time the filter needs replacing. That works better too.
Conclusion: Let's reduce air flow and stick with stock setup (both filter and housing). More air in doesn't apply here!
FYI...I am not disputing the fact that the stock filter is 99.9% effective. Just that the K&N filter w/precharger offers great filtration and flows better.
You are correct, the OEM paper filter does filter better!!!
Do you think K&N coming out with the "precharger" is their
way of admitting the standard K&N filter DOES NOT filter well???????
How do you know this? Most independent tests Ive seen show that not running a filter at all results in excellent flow and only slightly less filtration than the K&N. Seriously though, how much dirt does the K&N have to have in it before it starts filtering as well as the OEM? Then at that point, how well does it flow?
Go to the K&N website and see the results...to know they really work. If you do not believe K&N, do you believe Edelbrock with HP gains with the Performance Package...or FORD that the 6.0L really does have 500+ ft lbs of torque? Or should I go on? Again...missing the point psdwanabe. In your Scenario that would mean both filters would flow evenly "if" they were both installed in the restrictive housing. However, "if" using the K&N filter/Generation II FIPK kit and the precharger combo, the K&N setup would flow better due to the lack of the restrictive housing.
As to your "independent" tests, not sure what to say about that. Only that if K&N is making false claims regarding their products...well maybe I should call my attorney and file a class action suite? Care to join in?
Could very well be. However, the "precharger" is recommended in dusty and/or off-road conditions. Good insurance to use all the time...
If FORD would remove the restrictive housing and use the Donaldson brand filter with a Generation II FIPK type kit...then this thread would not be needed.
I called K & N filter company last week and asked them if a filter was available for the 6.0 diesel ford truck. I was told that it was not available and would never be available for the 6.0.
So I really don't know what all this nonsense about k & N filters are from. Someone needs to get there stories straight. Obviously someone had not done their homework.
Also, I read the forums a lot and have yet to find anyone that is completely satisfied with their Ford Truck (diesel). Why buy one if you can't appreciate them.. I love my 6.0 Ford diesel and yes, mine is a 2003 model.
Interesting...1badfx4. This is what I found on the K&N website for the 2003 F-250 6.0L engine:
Year Make Model Type Engine Type Comment Part Number Description
2003 FORD F250 Truck 6.0L V8 DSL Super Duty 57-2546 FIPK
