half breed help
Old Mar 29, 2004 | 12:58 PM
824x4ride's Avatar
824x4ride
Question half breed help
well i think my new truck is a half breed.... the new ride is a 72 f-100 4x4 but from what i am understanding the 72 didnt have disc brakes on the front as well from some searching iam understanding that disc brakes wernt offered untill 1976....can someone help with this info....and if my findings are correct how can i indentifie what frame and running gears are under my truck. ie: axle tags, frame tags, anything....this is turning into kind of a cluster but i still like the truck....any and all info is much appreciated
Old Mar 29, 2004 | 01:39 PM
bigf150's Avatar
bigf150
Somebody may have put a front disc setup on the truck aftermarket. All that i can tell you is that my half ton runs a dana 44 up front and a 9 inch in the rear. I hope this helps.
Old Mar 29, 2004 | 01:55 PM
824x4ride's Avatar
824x4ride
thanks bigf150...question for ya on your steering does the tie rod/ draglink connect at the passenger tire or is it the y type steering were they connect in the center ?..as well what year truck do you have?...thanks
