Sponsored by: Real Truck
Front Bumper
Old Mar 29, 2004 | 08:12 AM
rmilchman's Avatar
rmilchman
Front Bumper
I have an 02 F350, and will be replacing my front bumper. Does anyone know what's involved in removing the stock bumper and about how long it should take?
Thanks,
Rich
Old Mar 29, 2004 | 08:28 AM
DCSpecial's Avatar
DCSpecial
Six bolts total to get the stock bumper off a 2002. Two on each side of the tow hook and another one on each side inside the wheel well that bolt up to the spring hanger (if you look inside the wheel well it's easy to see the bracket going from the bumper to the hanger). Once the bolts are off you'll need to unplug the fog lights and if it's a PSD remove the block heater plug from the bumper. Removing mine with an impact and someone holding it up takes less than 10 mins.
Hope this helps.
Old Mar 29, 2004 | 09:16 AM
rmilchman's Avatar
rmilchman
Thanks, it is a PSD. Are the cables to the foglights and heater long enough that they can be removed after dropping the bumper, or do they need to be removed first?
Old Mar 29, 2004 | 09:17 AM
cwb's Avatar
cwb
Remove them first.
