Has anybody had problems with their factory clearance lights? Any leaks? I like the lights, but I do not like the idea of holes drilled in my roof. Thank you. Philip.
No leaks but did have to take it in a day or so after I got it for the drivers side not coming on (wasn't a bulb). Had to drop the headliner and reconnect the plug. I guess it must have come off, yeah right guess it was never connected.
I have a 04 F250 without the clearence lights and was thinking about adding them or possably a Lund Moon Visor . does anyone know if there is a factory wireing harness already there or will I need to run one. Either way is ok but would be great to save time and use factory wireing if there,, also Does anyone also know the ford part # for the factory lights. thanks
