Rough Running
Old Mar 28, 2004 | 10:23 PM
jimbo2000's Avatar
jimbo2000
Rough Running
Can anybody help?
I've got a 1987 F150 with a 302. I've just had the distributor, ignition module, canister fuel filter, plugs, plug wires, distributor cap and rotor replaced. It still doesn’t run right. It acts like it's starving for gas. I can drive down the street and it will suddenly cut out and sometimes kill momentarily. When I'm driving down the freeway at about 70 mph, and let off the gas momentarily. it acts just like turning off the ignition for an instant. Jerks the driveline violently. What gives?
Old Mar 28, 2004 | 10:27 PM
EPNCSU2006's Avatar
EPNCSU2006
See what codes are in the computer. Go to http://fordfuelinjection.com and click on "Getting Codes" if you don't know how to pull them. If your '87 is like mine, you'll need a volt meter to pull codes because the check engine light is not wired.
