Can someone give me the height dimensions for f250 and F350 trucks, 2wd and 4wd. I want to use this truck as my daily driver but need to park in a Parking garage.
My 99.5 2wd PSD on 265 tires is 76" high at the rear center of the roof. 4wd's are several inches higher depending on tires and what spring blocks they have
Overall height (empty)
F250 4x2 SC SB 76.6 in tires are lt235/85 r16
F250 4x4 SC SB 80.4 in
F350 4x2 SC SB 77.3 in tires are lt265/75 r16, 76.3 if dually and LB
F350 4x4 SC SB 80.7 in, 81.2 if dually and LB
The crew cabs are .1 or .2 in's lower.. (probably cause of the extra weight)
