91 explorer 4wd engine lurching
Old Mar 28, 2004 | 09:12 PM
starweb's Avatar
starweb
after sitting at a stoplight for about a minute, i notice that my rpm's drop and the engine starts to lurch. if i put it in park it goes away. besides that it runs good. anyone know what this is?
Old Mar 28, 2004 | 11:15 PM
c96drumm's Avatar
c96drumm
Might be the IAC needs cleaning or replaced. How long since plugs, wires, cap & rotor, air & fuel filters, PCV valve, etc. were done? Good idea to pull the codes, too.
Old Mar 28, 2004 | 11:18 PM
starweb's Avatar
starweb
ok, i am hoping it is just a tuneup. but, i donot know what IAC means?
Old Mar 29, 2004 | 12:34 AM
c96drumm's Avatar
c96drumm
Idle Air Control. It's a solenoid valve attached to the side of the throttle body that regulates air into the intake when the throttle valves are closed. They can get gunked up and not work properly. Can be removed and cleaned with throttle body cleaner.
Old Mar 29, 2004 | 09:46 AM
starweb's Avatar
starweb
ok, thanx i will check it out
Old Mar 29, 2004 | 12:00 PM
starweb's Avatar
starweb
IAC checks out at 9.6 ohms. just found out how much of a nightmare it is to get to the passenger side spark plugs.
Old Mar 29, 2004 | 12:14 PM
c96drumm's Avatar
c96drumm
I get at mine through the wheel well.
Old Mar 29, 2004 | 09:35 PM
golfboy17's Avatar
golfboy17
Please Note starweb that there is not cap and rotor on the explorers even first gen. its a sealed unit, they ussually dont need to be replaced cap and rotor are on older cars and most cars now a days dont use them, but eveything else c96drumm said is correct, you might also want to replace fuel filter and check fuel pump sometimes when fuel pumps are going they dont pump the fuel like they should, or a clogged filter.
