Sponsored by: Real Truck
end links/brake hoses
Old Mar 28, 2004 | 05:51 PM
mattsf250's Avatar
mattsf250
where would i go about purchasing these items from??
not sure if i even need the hoses..... i am installing 4" spring hangers, adjustable trac bar, longer shocks, either bilstien or rsx depending on cash flow next week, as well as 295/75/16's on my stock wheels....ohh, cannot forget about the f350 blocks.
if i am not mistaken, this should level the truck, and provide clearance for those tires through nearly any terrain...
i have a source for everything other than the sway bar end links, and extended brake hoses (assumin i even need them?)
AND IF YOU SEE ANYTHING OBVIOUS I MISSED....PLEASE SPEAK UP!
Old Mar 28, 2004 | 06:09 PM
DCSpecial's Avatar
DCSpecial
You don't need new sway bar links......if it pulls the sway bar up a noticeable amount you can just flip the stock mounts to under the frame rail.
You don't need new brake lines either.....the stock mount at the frame rail can either be bent and/or relocated if need be.
If you go with BE5-6245-H5 Bilsteins up front I think you'll want to run a 1" bumpstop spacer to prevent bottoming out the shock off road.
Old Mar 28, 2004 | 06:14 PM
mattsf250's Avatar
mattsf250
cool! great news, thanks man. i was rackin me brain on the end link issue.....so who sells bumpstop spacers, or new bump stops?
