Sponsored by: Real Truck
SD Rear Ends
Old Dec 9, 1999 | 07:42 PM
Todd's Avatar
Todd
SD Rear Ends
Can anyone tell me if the rear end in my 99 F250 SD Powerstroke is a "full floating" rear end and if its a Sterling 10.5? Does my 250 have the same rear end as the SRW 350? Any info would be greatly appreciated.
Old Dec 9, 1999 | 07:49 PM
J.C.'s Avatar
J.C.
SD Rear Ends
Yep, it's a full floater and it's a Sterling 10.5". It is also the same as a F-350 SRW, DRW's get a Dana80.
Old Dec 10, 1999 | 06:33 PM
Todd's Avatar
Todd
SD Rear Ends
J.C.
I thought that was the case, just wanted to make sure. Thanks for the quick reply.
Old Dec 25, 1999 | 08:38 PM
George's Avatar
George
SD Rear Ends
I have 99 SuperDuty CC SB SRW 4x4
Diesel w/Auto,6"Skyjacker
lift,37's,need to swap or trade or
buy different ring &
pinions.Preferably 4:30's.
I have 3:73's now. If anybody has
any leads just get in touch with me
Old Dec 26, 1999 | 10:02 AM
J.C.'s Avatar
J.C.
SD Rear Ends
A 4.30 axle ratio is an option on Super Duties with the V-10 so, I see no reason you just couldn't get them from Ford. I doubt you'll find too much aftermarket since this is the first year Ford has used the 10.5" rear ends. However, it's my understanding the 10.25" and 10.5" uses the same housing so, it all else fails you could just swap in gears for the 10.25".
Old Dec 26, 1999 | 06:53 PM
whd507's Avatar
whd507
SD Rear Ends
twall_SD250
Jun 16, 2016 08:49 PM
sitInHigh
Appearance & Dress-Up
Jul 25, 2013 10:37 AM
Ford Bandit
Oct 8, 2010 07:50 PM
MikeSD
May 15, 2004 01:33 PM
