Preparing to Install Highboy Lift
Old Mar 28, 2004 | 01:13 PM
dabmdb's Avatar
dabmdb
OK, the 4" Skyjacker kit has arrived, consisting of new front and rear leaf springs I plan to install myself on my 75 F250 4X4 highboy. I can drop the old springs no problem, I'm concerned about any "alignment" the solid axles will need since they will be "free" for a few moments. Can I replace the leafs on one side at a time, will I have enough play if the opposite side is still secured? Make a mark where the old spring pack sat and line the new ones to it? In otherwords, is the an appropriate job for the backyard mechanic? I've got all the necessary jacks and stands etc.
Thanks,
Don
Old Mar 28, 2004 | 03:16 PM
AirSmitty's Avatar
AirSmitty
Your new springs should have a shallow hole in the bottom of them. The top of the axle has a plug to go into that hole, so you shouldnt need to mark anything. It should just line up.
