1978 - 1996 Big Bronco
How do I...........
Old Mar 28, 2004 | 12:44 AM
YankeeFan's Avatar
YankeeFan
How do I...........
I am a new Bronco owner and as such I need help getting info on a couple of things on the rig. It is a 1990 Bronco with the 5.0L V8 with an automatic transmission. I am wanting to know how to find out what gears it has and what tranny it has in it. What do I look for? Where do I look for it? Thanks for your help.
Old Mar 28, 2004 | 01:29 AM
BroncoRoadKill's Avatar
BroncoRoadKill
Look on your dor tag and it should have tranny and axle codes, and also, there should be tags bolted to the front and rear diffs.
You can post the codes here and we can dicifer them for you.
Old Mar 28, 2004 | 12:15 PM
RLKBOB's Avatar
RLKBOB
Your axles are 3.55:1 and your trans is either AOD or E4OD, here's how you tell the difference:
AOD - P R-N-OD-D-1
E4OD - P R-N-OD-2-1 with an "overdrive off" push button on the dash.
Old Mar 28, 2004 | 05:06 PM
bronco5.8's Avatar
bronco5.8
Yankeefan,
Give me the numbers for the axle and trans on your door jamb and I'll tell you exactly what you have.
Warr
Old Mar 28, 2004 | 08:55 PM
RLKBOB's Avatar
RLKBOB
Don't take this the wrong way but if he looked at my post then he already knows.
Old Mar 28, 2004 | 11:48 PM
BroncoRoadKill
But you told him what he had, without even seeing any #s. He could have the optional 4:10s, or 3:73, or even 3:08.
Too say you have this axle ratio is not right, you can however say he has very good odds that his gears are 3:55. Not putting anyone down, but we should be more open minded and maybe use our heads when posting.
mrduke41
Dec 24, 2012 12:06 PM
RussF350
28
Nov 12, 2012 07:17 AM
hunter27
Feb 8, 2007 10:30 PM
v guy
Apr 6, 2005 06:39 PM
