question on 2.9 liter
Old Mar 27, 2004 | 09:12 PM
Cmq44's Avatar
Cmq44
I bought this motor new from ford...well actually remanufactored. My question is...i was told that ford redone the heads for the 2.9. And i was told that the heads on the remanufactored motor were the revised heads. I recently ran the truck hot because i didnt know the intake gaskets blew and anitfreeze drained into the oil pan. The heads that are on the truck now are iron heads and i was told those are very hard to crack and not to worry with them....(this is from a ford master mechanic) Make a long story short, i drove the truck for 3 weeks no problem then i started hearing clatter. My rod bearings were giving out. i figured this is from the anitfreeze front the intake leak. I am now replacing the crank and main and rod bearings in the truck. I dont want to pull the heads if i dont have to but does anyone this when i overheated the motor that the heads could have cracked? Like i said i have drove the truck for 3 weeks and no problem and its holding antifreeze fine, other than the water that was in the motor from when the intake gaskets blew and i just changed the oil (which was the first time since i got the truck back) right before i pulled the motor. But i have kept a close eye on the oil and coolent since i got it back. I am a student driving 1 hour each day to school one way....so i need durable trasnportation. Your help is greatly appreciated. Thanks again.
Cmq44
Old Mar 28, 2004 | 08:17 PM
Ken00's Avatar
Ken00
Ford did revise the heads in 1989 but they still crack very easy.
