Sponsored by: Real Truck
Where to get Bilstein Stablizers
Old Mar 27, 2004 | 05:48 PM
Yeti's Avatar
Yeti
Pretty self expanitory, where can I get them, don't really need the brackets, just the shocks themselves.
Cheapest place???
Part #S??
Yada yada yada
Old Mar 27, 2004 | 05:57 PM
DCSpecial's Avatar
DCSpecial
I'd recommend Truck Toyz 1-888-776-8699......talk to Marty or Kevin.
I'm not sure on the part number since I think it's still a reworked shock....they'll know the part numbers though.
Hope this helps.
Old Mar 27, 2004 | 06:14 PM
maximnole's Avatar
maximnole
Part# is 3-BES 6253-HS-R.........I got mine from Superduty Headquarters..I think the prices are all with in a couple bucks where ever you get them.
Old Mar 27, 2004 | 06:16 PM
MrRottnDog's Avatar
MrRottnDog
I got mine from Marty also.
If you just want the shocks and if Bilstein is selling that model number with that valving now. You might try shox.com. Thats where I bought my 7100's.
Old Mar 27, 2004 | 06:17 PM
Yeti's Avatar
Yeti
Cool thanks guys...
They are the 5100's?
Old Mar 27, 2004 | 06:25 PM
MrRottnDog's Avatar
MrRottnDog
They are 5100's... but I understand they were valved by or for DR specifically for use as dual stabilizers.
There is someone here in this forum who has them mounted using a less expensive bracket. I can't think who it is right now..... maybe hirolln?
Old Mar 27, 2004 | 06:30 PM
DCSpecial's Avatar
DCSpecial
Yeah, they are 5100s that originally are for a different vehicle and then they are reworked to be setup properly to be run as a dual opposed stabalizer..........eventually (no idea when this will happen) they will come with that valving from the factory and not need to be reworked.
Old Mar 27, 2004 | 06:56 PM
HeavyAssault's Avatar
HeavyAssault
Are they specific for either side?
Old Mar 27, 2004 | 11:13 PM
DCSpecial's Avatar
DCSpecial
Same shock on each side....valved the same, which they have to be to work properly in a dual opposed setup.
Old Mar 28, 2004 | 08:01 AM
maximnole's Avatar
maximnole
I have them and use the BDS dual bracket. They are the 5100's. They give a great steering feel over bumps while turning. No steering wheel kickback what-so-ever and at the same time not being stiff.
