pre-oiling a 292
Old Mar 27, 2004 | 01:21 PM
bigvinnie's Avatar
bigvinnie
pre-oiling a 292
Needing to pre-oil a fresh 292 that has sat for 2 years..... changed the oil, pulled the distributor and got a 1/4 deep socket on an extension chucked up in a variable speed drill, spun the pump shaft counter clockwise for a minute or two, expecting to see oil at the rocker shafts, but no dice...
There appears to be a fair amount of resistance when turning the shaft, and I can hear the pump making some faint clicking noises, which indicates to me that it's pumping oil, but I'm not seeing any at the rockers...
Am I doing something wrong or is it possible that the pump is having problems of some sort...???
thanks for any help.
Vince
Old Mar 27, 2004 | 01:46 PM
312's Avatar
312
it should only take a minute to get oil up.by any chance are you using a cross drilled cam.if this is the case turn the engine over a little.
Old Mar 27, 2004 | 01:55 PM
bigvinnie's Avatar
bigvinnie
thanks for the quick response... not sure if the cam is cross-drilled, but I'll rotate the motor a bit... gotta put the distributor back in first so I can make some new marks on the firewall to keep from getting lost...
what's the significance of the cross-drilled vs. not cross-drilled...???
thanks
vince
Old Mar 27, 2004 | 02:33 PM
bigvinnie's Avatar
bigvinnie
It Worked !!!
Thanks 312 for the suggestion... guess my cam is cross-drilled.
Is that good or bad..??? Is one better than the other..???
Vince
Old Mar 27, 2004 | 06:44 PM
312's Avatar
312
cross drilled cams were used on 54 and 55.it was just a diffefent way of oiling the rockers.some say it was better than the grooved cam.others don,t.
