Rattling in Door/Window
Could someone instruct me how to pull the door panel off? There doesn't seem to be any fasteners in view. Do I literally "pull" the panel off?
Thanks.
If not here.............you might want to try over in the Super Duty forum.
Hope someone can help
My rig makes a rattling noise from that same area as yours. I find if I put pressure on the upper back corner of the door panel the noise stops. Have not had a chance to see what it is yet, but the door panel was off when I put in new speakers -- so there may be an issue with how the panel went back on.
If you have an '03 or newer SuperDuty, if I remember correctly you have to pop off both the lower reflector lense and the sail panel to get to screws. Then unplug the controls for the PW/PDL switches. Then the panel is ready to come off.
This part is important...do not pull the panel away from the door!!! It lifts off by pulling up on it! After a few tugs and realizing it was not budging I figured this out.
Hmmm, I did the driver's door first...this may have something to do with my noise...
