10.25" dually conversion
Old Mar 27, 2004 | 11:16 AM
oldhalftons's Avatar
oldhalftons
What will it take to put dual rear wheels on a F250 with the 10.25 sterling full floating axle?
Are the actual dually rear ends wider or are the hubs just different? I dont care at all about the front using the same rims so its just the rear end?
I'd like to do this (if possible) without expencive aftermarket kits.
What are my options for this project?
Old Mar 27, 2004 | 03:51 PM
Txquadhunter24's Avatar
Txquadhunter24
dually's run the dana 70 rearend. I haven't heard of making the 10.25" into duals. your best bet is to find a factory dually to rob the rear from. make sure it's a factory bedded dually because the factory cab & chassies use a norroer frame.
do a search in this forum you'll find a complete write-up of this swap. I believe it was by greywolf. it'll step you riight thru it.
Old Mar 27, 2004 | 08:36 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Good idea on using the Dana 70. It's a stronger axle anyways and would be a bolt-in swap as long as the gear ratio is the same. You didn't say what year your truck is. I don't know what year they started using it, but the later trucks (say, ~'89 and up) have a speed sensor in the rear axle for the ABS and electronic speedo. I think dually's also used different width rear springs, but I don't know if that would be an issue as long as you use your current springs.
Old Mar 27, 2004 | 10:17 PM
Wrecker's Avatar
Wrecker
Im doing a similar swap. I did a search and can't seem to find the thread your talking about. Any other search tips to help find the thread would be very much appreciated.
Thanks
Wrecker
Old Mar 27, 2004 | 11:04 PM
Txquadhunter24
heres the link
https://www.ford-trucks.com/forums/s...hreadid=199713
humphrey169
Competition
Aug 25, 2018 11:50 AM
82f3504x4
62
Mar 25, 2017 06:25 PM
larrylass
Oct 21, 2010 12:20 PM
tjbeggs
13
Nov 22, 2006 08:20 PM
orange78oval
1978 - 1996 Big Bronco
Jan 25, 2004 08:11 AM
