Bronco II Ford Bronco II
help!!! starting problems
Old Mar 27, 2004 | 09:28 AM
jakes29's Avatar
jakes29
Unhappy help!!! starting problems
I have an 87 b2 2.9 4wd. last night i got into to start the truck, turned the key, the engine started but the ignition kept cranking and cranking like I had turned the key too far. it kept cranking until it drained the battery. I tried to jump it but as soon as i touched the cable to the positive post, the truck jumped like it was trying to start even though i had the keys in my hand!!!
is the starter stuck? i had a similar problem with it not starting about three years ago and had the fuel pump relay replaced. please help!!!
Old Mar 27, 2004 | 09:50 AM
68torino's Avatar
68torino
Change the soleniod first. For the starter to keep running the solenoid needs to be engaged to send current to it.
Old Mar 27, 2004 | 10:03 AM
jakes29's Avatar
jakes29
I replaced the solenoid about a year ago. would it have gone out already?
Old Mar 27, 2004 | 10:11 AM
68torino's Avatar
68torino
It can. It is worth a try.
If that dosen't cure it, there is a possibility the start function in the key system is hanging up. I would try the soleniod first.
Old Mar 27, 2004 | 11:12 AM
jakes29's Avatar
jakes29
Thanks for you most useful info torino. it is much appreciated. im sure i will have another question here soon!!!
Old Mar 27, 2004 | 11:55 AM
jakes29's Avatar
jakes29
i recently have been having problems with my b2 dying while i am driving. the rpms drop dramatically. sometimes i can catch it by tapping the gas pedal so it doesnt die. this is a potentially very dangerous situation for me. is this related to the solenoid problem? or could it be a fuel pump/filter problem? i changed the fuel filter ( the one under the driver side door) about three weeks ago but it didn't seem to help.
Old Mar 28, 2004 | 01:44 AM
87 XLT's Avatar
87 XLT
Like 68torino sez, it might be a bad ignition switch. Try this: remove the slip fit wire from the starter relay, if it stops cranking replace the ignition switch
Old Mar 30, 2004 | 01:59 PM
jakes29's Avatar
jakes29
well, I ended up installing a new starter and solenoid. it now starts within two seconds (like it should). my starter had been going out for about a year. i am surprised it lasted that long. thanks to everybody's input!!!
