Gas Gauge Problem
Old Mar 27, 2004 | 09:24 AM
MrLogic's Avatar
MrLogic
Gas Gauge Problem
I've noticed that my Expy gas gauge has developed a problem. If I crank the vehicle immediately after putting gas in, the gauge does not register correctly.
For instance, if I have a 1/4 tank and put $38 worth of gas in it, the gauge remains at 1/4 tank. The only way I've been able to get the gauge to go up to full was to turn the key and wait for the gauge to go to full and then crank the vehicle. If I crank it right away, it doesn't work.
It didn't use to do this and I recently had coil pack #7 replaced and air induction cleaned and fuel filter replaced and noticed it since that has happened.
Any ideas on what could be causing this?
Thanks everyone, appreciate any advice you might have.
Old Mar 27, 2004 | 12:07 PM
turbo TED's Avatar
turbo TED
MrLogic; This is how my 97 expy started its guage issues & the dealership went bezerk trying to find the issue, & they did not [WHEN YOU WANT SOMETHING DONE CORRECTLY DO IT YOUR SELF] they replaced the sending unit the float & nothing what it wound up being was the the big thirty or
someodd pin connector on the back of the insturement cluster pod, as you are facing the cluster it is the one on the left side, the pins are of a cantalever design & they just seemed to get a little loose I took a dental pick
& just pulled the pins out just a little bit, the way to find the correct pins on the harness is just follow the copper circuit on the back of the unit to the pins on the harness [ I just did all of them just to make sure that I did the job right the first time]. As soon as I put it back together & turned the key it came right back up to the 3/4 mark & that did corespond to the amount of gas & mileage on the overhead consle. The way I knew the problem was in the back of the cluster was because I hit a pothole & it marked correctly for about one mile & then went back up to the beyond full mark [past the f]
looking the schematic for the pod wireing if it looses contact it goes in to open loop thinking it is totaly full. This repair cost me nothing & was a permanent repair to the vehicel all the way up till I traded in for my current
expy. TURBO TED
Old Mar 27, 2004 | 05:21 PM
MisterCMK's Avatar
MisterCMK
Don't you hate it when the problems are the little remote things that nobody thinks of? I know I do.
Old Mar 27, 2004 | 06:46 PM
MrLogic's Avatar
MrLogic
Thanks for the feedback, I will take a look and see if it might be the same thing. Thanks again for passing along the info.
