Thump and bump
Old Mar 26, 2004 | 11:36 PM
Hsi95's Avatar
Hsi95
Red face Thump and bump
Hello All,
Have a problem that I have researched on FTE But to no avail..
When accelerating from a stop a thump is herd and "Felt" towards the rear of the truck.
95 F-150 4X4 Rancho Lift 97,000 miles.
I replaced the trans mount and the engine mounts and the thump still is there.
Took it to a Four wheel shop today and the Tech had no idea what was causing it.
He recommended a trans shop. I have read quite a few Fixes but nothing definative. All bushings, mounts, and springs are intact. Trans has 30,000 on it and no leaks.
Sugestions?
J.
Old Mar 26, 2004 | 11:40 PM
pops_91710's Avatar
pops_91710
I was thinking it may be the carrier bearing on the drive shaft. But the tech would have caught that, right?
Old Mar 26, 2004 | 11:54 PM
Hsi95's Avatar
Hsi95
Hey Pops,
Possiably, Not sure.
The tech was stumped so, Most likley off to the trans shop as recommended.
Just want to avoid throwing money at the problem.
Thanks for the hint though.
So far i have a list for the next tech to look at.
Slip yoke
Trans modulator
vac lines
U-joints
Tranny not dropping into 1st gear when stopping.
Trans tailshaft bushings loose.
Carrier bearing on Drv. shaft
Thanks for the Idea.
When i find out what is causings I'll be sure to post it to help other users save a few bucks and aggravation.
Cheers,
J.
Old Mar 31, 2004 | 11:57 AM
Hsi95's Avatar
Hsi95
Hi Pops,
Fixed the Thump bump and jerk on acceleration.
Turned out to be the slip yoke.
Had it Lubed at ford for $30 dollars and presto! it is fixed.
Thanks again for the suggestions.
