Static Shock
Old Mar 26, 2004 | 06:38 PM
sand dollar's Avatar
sand dollar
Question Static Shock
Just wondering, almost every time I get out of my truck and touch the door to close it, I get zapped big time...
I have not notice this on any of my past cars....I remember ground strips from the 60's, is this a solution? or, is there something else?
Old Mar 26, 2004 | 08:22 PM
DucatiSSsp's Avatar
DucatiSSsp
The grounding strip is the solution...I inquired at the dealership when my escort GT did the same thing. Or try closing the door with your tennis shoe
Cheers,
Bryce
Old Mar 27, 2004 | 11:27 AM
Hunter40's Avatar
Hunter40
All three trucks I've owned did this. What's a grounding strip, wasn't alive in the 60's.
Old Mar 27, 2004 | 02:38 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I thought I was the only one with that problem, and because our average humidity is 18% then that would explain it. Now with some one in Virginia, lots of moisture, I am wondering.
Old Mar 27, 2004 | 09:06 PM
Hayapower!'s Avatar
Hayapower!
I used to have to carry a can of laundry "anti static" spray and give the seats an "ocasional shot" in most of the static months.. REALLY helped..I can beat my knuckles bloody, but hate to get shocked!!!!
Old Mar 28, 2004 | 06:52 AM
IB Tim's Avatar
IB Tim
My worry.............over time can it resuilt in problems for the computer.
Shock that is!
Old Mar 28, 2004 | 11:28 AM
westwardbound's Avatar
westwardbound
I just logged on to ask the same question. It seels lije the shocks are getting stronger. We need a fix soon or one day I'm going to get zapped so bad I'll be knocked to the ground.
Old Mar 28, 2004 | 12:13 PM
IB Tim's Avatar
IB Tim
I blow a spark that will ultimately get me on the 6pm news. If at a gas station, I am going to blow my butt into the next zip code. The problem is I do that with any car any time, it is not specific to my Ford truck.
Old Mar 28, 2004 | 01:09 PM
SBV45's Avatar
SBV45
ESD (ElectroStatic Discharge) is very damaging to electronics as well as uncomfortable to the CBU (Carbon Base Unit=mammal). It is caused by your clothing rubbing on the upholstery. If you are wearing a synthetic material jacket, shirt, sweater, etc., as you slide in and out of the vehicle, you become charged. You probably have rubber soled shoes and rubber floor mats, the charge has no where to go except to the path of least resistance like your fingers and the metal parts of the truck. Hayapower has a good suggestion with the laundry anti-static spray.
I wouldn't worry about the PCM unless you are disassembling it.
Old Mar 28, 2004 | 01:10 PM
johnsdiesel's Avatar
johnsdiesel
At least when you fill your diesel that can't happen.
Old Mar 28, 2004 | 03:30 PM
IB Tim's Avatar
IB Tim
My relatives are happy it has a low flash point.
Gas well........
Old Mar 29, 2004 | 08:19 AM
$trokin60's Avatar
$trokin60
Here is a little secret to get around the shock. Hold onto a metal part of the truck (the outside of the door works) before putting your foot on the ground after your foot reaches the ground release the metal. This causes the spark to jump from your shoe to the ground instead of your finger to the door. Another safety tip (before fueling) take the fuel nozzle in one hand before placing it into the tank touch the vehicle with the other hand this grounds you the vehicle, and the nozzle. It causes the spark to jump from you to the truck insted of the fuel nozzle to the truck. Dont have a cell phone on or around you when fueling they produce bigtime static when the ring. hope this info is helpful Jerry United States Army Aviation Safety.
Old Mar 29, 2004 | 08:38 AM
IB Tim's Avatar
IB Tim
Good point , I NEVER have my cell phone around, I am even worried it is with in 20 miles.................me and my shock and all
Old Mar 29, 2004 | 09:14 AM
johnsdiesel
Actually the whole cell phone myth has been put to rest. There have actually never been any incidents caused by a cell phone. (talking about gasoline)
Old Mar 29, 2004 | 09:26 AM
Bushwhacker's Avatar
Bushwhacker
I have a solution to the static shock thing. I have to wear ESD boots (electro static dissappating) for work and I never have a problem with getting static shocks when I have them on. I found out that it works great at home in the winter time. If the old lady is acting up and she's been walking around on the carpet I just have to go up and touch her and she gets a real good jolt while I'm oblivious to it (as long as I have my ESD boots on). Its kinda like when you grab some ones hand and then grab an electric fence. Oh what fun you can have with electricity!!
