Dumb question RE: switches
My dumb question is this. Can you disconnect the switch from the switch cable or the chip without disconnecting the battery cable? I have two reasons for asking. One being that I have not permanantly mounted my switch and two being that the module I recieved did not have the "retention loop" where the cable plugs into the chip. I know most will say "suuuure it was broken off when you got it" but it really was. If it were to somehow overcome my "tape retention system" that I came up with where he cable comes out the back of the computer through the big sticker and vibrate loose from the chip, would it cause a problem?
If it's not an issue, I am thinking I'll probably upgrade to a illuminated switch so I'll know for sure it is connected.
