Sponsored by: Kumho
brake problem
Old Mar 26, 2004 | 12:12 AM
bigtigger_ore's Avatar
bigtigger_ore
Exclamation brake problem
[I have been told that i need to reset my brake differentail valve, where the brake lines go after the master cylander, how do i do this? my front brakes have fluid but no matter how long i try the back won't get fluid????
Old Mar 28, 2004 | 10:38 PM
weldingfreak's Avatar
weldingfreak
I have the same trouble. look at the link to see how to fix check out the second to last reply for the info
https://www.ford-trucks.com/forums/s...d.php?t=216078
Old Mar 28, 2004 | 10:47 PM
weldingfreak
Get under truck at the valve there is a nut with a rubber cap take off the nut there will be a spring and a plunger that will be in there(don't lose them) The spring will come out eazy enough the plunger will probley be stuck so carefully remove.
note: at this time you will have a freeflow of brake fluid.
Replace plunger and spring and nut/cap( it is a little tricky) Then bleed the brakes as normal
Old Mar 29, 2004 | 11:42 AM
bigtigger_ore
Thanks Ill try that
Old Apr 21, 2004 | 12:04 PM
PoolBoy's Avatar
PoolBoy
did you get this problem taken care of? if not I had the same problem I took the proportioning valve off and used an air hos to see if i had a clog, this may stop the fluid from reaching you back lines, old fluid can solidify and clog the valve. If it's not clogged you should be receiving fluid in the back lines.
02GrayPowerStroke
Sep 16, 2018 02:30 PM
plummer
1997 - 2003 F150
Mar 12, 2015 09:03 PM
jonmammenga
Nov 17, 2014 09:15 PM
monster79f150
May 29, 2011 12:44 AM
Gans
Jul 11, 2010 08:53 PM
