engine swap
Old Mar 25, 2004 | 10:49 PM
b-barke8's Avatar
b-barke8
engine swap
was womdering if anyone knows where I can get motor mounts for a 302 to fit into a 69 f100 that has a 300 six in it now. also where to weld them in
Old Mar 26, 2004 | 09:00 AM
talisker's Avatar
talisker
I am not sure about the "mounts" for the 300 to 302 swap you want to do. I am assuming that you mean the perches that attach to the frame rails. I just did a swap last summer and put a 360 in my 69 F100 in place of the 240 (same block as the 300). In my case the perches had to be moved to the rear position. It did not require anything other than unbolting them from their fron postion and moving then back about 2 or 3 inches. The holes were already there. My only problem was the rust on the bolts required the application of the ever pesent heat wench to cut them off. I think that in most cases Ford to Ford swaps are pretty easy.
Old Mar 26, 2004 | 05:41 PM
roadgemF100's Avatar
roadgemF100
There's no welding involved with your engine swap. You just need to get your hands on a pair of 302 engine perches and it will bolt right in. I've got a set in a truck I'm stripping down...but I probably won't have them out for a couple weeks, due to other obligations. If you're interested, e-mail my username at Yahoo.com.
Old Mar 28, 2004 | 10:54 PM
FE427TP's Avatar
FE427TP
Are you sure this is right? because when I swapped the 240 for a 360 on my 68 I had a set of the FE mounts and the straight six mounts and side by side they are different, when swapped out they bolted into the same spot as the 240, but everything lined up correctly afterward and didn't with the 240 stuff
Old Mar 28, 2004 | 11:22 PM
Mil1ion's Avatar
Mil1ion
Quote:
Boy, I thought EVERYONE knew what a transducer was. It is the voltimeteroptic sphere of the bloviastic concentric pulsating seismical atmospheric waves that result in the reduction of the staticalogical influence that causes coil breakdown.
I think he meant Step-down tranformer
Transducer is the vacuum/electric cruise control determining switch
Tongue in cheek comment is over
Old Mar 29, 2004 | 07:09 AM
roadgemF100
I just compared the 240 perches from a '67 with the 360 perches from a '68, and they are identical. As noted, they mount in different sets of frame holes, but other than that, there's no difference. The 302 perches are completely different, however.
Old Mar 30, 2004 | 12:39 AM
ACESN8S's Avatar
ACESN8S
What do you have in it now?
The only "M" motors I know of are the 351M and 400
You will probably have to change frame mounts, move the tranny crossmember, and get a different driveshaft.
I'm pretty sure the motors came in the later 70's trucks, 77 and later I think.
Old Mar 30, 2004 | 09:35 AM
talisker's Avatar
talisker
The 240 to 360 change I did definately used the 240 perches on the 360. I moved the crossmember back but as with the perches the holes were already there. The drive shaft was not modified. It had less spline exposed with the 360 is all. The engine was given to me, in BAD need of a rebuild, and came out of a '73. The perches from the '73 were way different.
