400 distributor rework?
Old Mar 25, 2004 | 07:31 PM
tastyklair's Avatar
tastyklair
I have a 410 with 8.7:1 cr. edelborck performer, 600 edebrock carb, crane cam with a 2000-6000 powerband, headers, 350 gears with 33" tires. I've read numerous posts but dont' quite get the drift yet of what I need to look to do to the distributor. My main concern is having it properly curved and the right advance mechanism on it. I have no emmissions crap on it however it was originally a smogger with egr, air pump, cat etc. Many moons ago, ( about 30 years now) I used to rebuild and curve distributors in a speed shop but that was a different age, so I'm not unfamiliar with things, however I don't have access to a Sun or Allen machine like I used to.
Old Mar 25, 2004 | 07:47 PM
danlee's Avatar
danlee
Do you have a high stall converter? What Crane cam do you have? What is your manifold vacuum at idle?
Old Mar 25, 2004 | 08:43 PM
tastyklair's Avatar
tastyklair
I'll check the vacuum tomorrow. Cam is Crane powermax h-272-2
lift intake 524
exhaust 519
Duration at .050 intake 216
exhaust 228
Old Mar 25, 2004 | 08:59 PM
danlee's Avatar
danlee
I used that cam with my 4V Cleveland heads. That cam requires a high stall converter, I used a TCI Saturday Night Special.
That cam has an IVC of 72 degrees, you don't have enough compression for that cam, you need more than 8.7:1. I think that Crane recommends 10:1 or higher.
Give me your specs: Bore, stroke, head ccs, head type, piston dish cc's, and deck clearance, I'll simulate the motor.
Old Mar 26, 2004 | 04:43 AM
SuperFord211's Avatar
SuperFord211
I'd Appreciate Your Opinions/simulations
I have a fresh 400 with some goodies. Just want to know what its capable of and what you guys think of it. Also what might I have done differently?
Specs:
Bore: 4.04
Stroke: 4.00
Heads: 80cc, 9.2:1 comp., 2.04/1.65 valves with 20 degree backcuts, fair amount of porting-polish chambers, exhaust humps removed, exhaust ports polished and cleaned up, intake cleaned up.
Pistons: Silvolite Hypereutectic 351c with 4.5cc valve relief 1.67 comp ht.
Deck Clearance: .045"
Cam: Custom Ground Comp Extreme Energy 4x4 210/218@.050 dur, .510/.524 lift, 8 deg overlap, 107 deg centerline, 111 LSA
Valve Timing:
Int. 2-BTDC 32 ABDC
Ex. 44 BBDC 6- ATDC
Rockers: Crane Energizer Street/Strip full rollers 1.7 ratio
Intake: Performer 400
Carb: Performer 750
All of this is in a 79 F150 4x4 backed by a stock C6 with a TCI Sat. Night Special HD converter and TCI SFI approved HD flexplate (cause i exploded the stock flex plate ).
Old Mar 26, 2004 | 06:57 AM
danlee's Avatar
danlee
That is OK. The torque is nearly flat from 440@2000 to 432@4000 RPM, with a peak of 446@3000 RPM. The HP peak is 348@4500 RPM. That cam is alomost the same as a 265DEH, with a liitle higher lift.
The Dynamic Compression Ratio is 7.7:1. It should run on any 91 or over gas. If 93 Octane is available in your area, you could have gone up to 0.5 higher in the CR.
With a 1.67 CH piston your deck clearance should be 0.0365. I used your figure of 0.045.
I assumed that you have headers in these calculations.
I don't think that you need a high stall converter with the small overlap of that cam.
Old Mar 26, 2004 | 10:09 AM
beartracks's Avatar
beartracks
I have found that a set up like yours responds well to a lot of initial timing but you need to limit total to 38 or so.
Old Mar 29, 2004 | 10:53 PM
Ecuri's Avatar
Ecuri
Can you recommend spring/weight combo's and who has them?
Who makes the adjustable vacuum advance? I need all this stuff also.
