Temp settings - Canadian trucks
Old Mar 25, 2004 | 02:40 PM
PC Poppy's Avatar
PC Poppy
Just tested my A/C today and the lowest I can set the temperature is 16 Celcius. In fact it goes down one degree at a time until 19 c then jumps down to 16 c. Is this normal with other Canadian 04s?
Old Mar 25, 2004 | 03:32 PM
2004lariat's Avatar
2004lariat
My wife's 03 Explorer does that as well (jumps from 19 to 16). It's normal.
Old Mar 25, 2004 | 03:44 PM
1956MarkII's Avatar
1956MarkII
If you go to the opposite end of the temp range, it will jump from 85F to 90F (your 19 to 16 jump is equal to a 65-60 drop here). These are the MAX settings, will cause fan to go to highest speed and STAY there till you change temp manually.
Old Mar 26, 2004 | 06:34 AM
PC Poppy's Avatar
PC Poppy
If that is the lowest setting, do you still get sufficient cooling for those 30 plus C days? Any complaints about not cooling enough? We here in the cold north haven't had a chance to give it a workout - yet!!
Thanks
Old Mar 26, 2004 | 07:22 AM
dusty1's Avatar
dusty1
I read a previous thread that discussed the inability of the ETAC system on the Lariat to work properly. From what I read, when the ETAC is set to AUTO, it takes the outdoor temperature and uses it to base how it cools (or heats) the interior. The system does not seem to take into account the impact on the interior of the sun beating through the windshield.
We had a couple mid-70s days here in Virginia a couple weeks ago (in fact, it's supposed to hit 73-75 deg F here today), and I noticed that when I set the ETAC system to 70 degrees, it was still much hotter in the truck due to the sun being out. On cloudy days it seems to work better, so that would lead me to believe it doesn't take the greenhouse effect into account when the sun is out.
In order to get the interior comfortable, I had to turn the AUTO setting to off and set the system on MAX AC to get the interior cooled down. It was only in the low 70s outside, so I shudder to think what it will be like when it gets up to 100F here.
I'm hoping that before summer arrives, Ford might be able to reprogram the system to work better. It's great that so many problems can be fixed now with a simple download! In the old days, you were just plain stuck with it.
Perhaps some of the Ford techs that read this forum can answer your question with a more technical explanation. I can only tell you what I have experienced so far.
Old Mar 26, 2004 | 07:52 AM
PC Poppy's Avatar
PC Poppy
Good explanation - thanks. How do we set the electronic controls to max cool?
Old Mar 26, 2004 | 11:09 AM
dusty1's Avatar
dusty1
I make sure AUTO is off, I set the thermostat at 60 degrees, and I put recirc on. That's the only way I know to set it for max cooling.
