proper way
Old Mar 24, 2004 | 09:44 PM
jhromy's Avatar
jhromy
proper way
What is the proper way of using these paint pens?? I have a couple scratches on my explorer, near teh door stricker so its not too noticable, is it easy to do??? looks pretty simple and the scratches are just straight lines. thanks guys
Old Mar 25, 2004 | 02:22 PM
CobraXP's Avatar
CobraXP
We are on too many forums together....
Like I said with the other reply and one of the other guys said - don't use the wet sandpaper unless you are comfortable with it. I've seen people try this before and mess it up worse than it was before.
I doubt you will have a problem. Put it on in thin lines, let it dry, and repeat. You'll be alright...
Old Mar 25, 2004 | 02:57 PM
jhromy's Avatar
jhromy
lol yea we are in a lot of the same forums...you must be following me around...lol jk...thanks ill apply a little at a time, im sure ill do fine, if i don't its only on the inside of the door, no one can see
