Motor and oil return question
One.. on a 1984 Ford F150 what is the letter "F" stand for in relation to type of motor?
Next thing....where us the oil return located at on the engine? Is it possible to be clogged and how do I unclogg it?
Drain the oil and replace the oil filter and fill the required amount of OIL. You might want to use 5W30 temporarily and change the oil again around 2,000 miles or less and use again the GUNK Motor Oil Flush and then use 10W30 or other higher type motor oil that you use.
