Sponsored by: Innova
sub ohms
Old Mar 24, 2004 | 08:03 PM
Benny R's Avatar
Benny R
Question sub ohms
I just bought a Rockford 650 watt 4 channel amp from my freind thats only one year old. Should I buy 2, 4 or 8 ohm subs (two 10 inch) and how should I wire them so they pound the hardest. Thanks for any help.
Old Mar 24, 2004 | 08:07 PM
jad1097's Avatar
jad1097
It would help if you were more specific about the amp. What model#?
Old Mar 24, 2004 | 08:14 PM
Benny R's Avatar
Benny R
Sorry, The verification certificate says modle 500x all channels driven to full power at 2 ohms=653 watts
Old Mar 24, 2004 | 08:48 PM
acerockola77's Avatar
acerockola77
I'd get two 4 ohm and wire them in parallel to create a 2 ohm load on the amp.
Old Mar 24, 2004 | 08:51 PM
Benny R's Avatar
Benny R
I'm fairly new to car audio so how do i wire them parallel and there is a little switch on the side that goes fron 2 to 4 ohms. do i switch it to 2 ohms
Thank you very much
Old Mar 25, 2004 | 10:45 AM
brianas's Avatar
brianas
considering that it is a four channel amp
I would probably run it bridged -2 channells to each sub
and use 4ohm single voice coil subs
that is a very simple setup and you should have no amp troubles with that
g/l
