what is a 429 thunderjet?
#31
I had two of these Thunder Jet 429s, one was in a 1970 LTD Brougham 2dr hardtop. the other actually started as a 2V in a 1971 Colony Park. Once I found the only difference was the intake and carb, it quickly became a 4V. Both great cars, strong engines. The low octane gas finally got the Colony Park engine, it cracked a piston and took out one cylinder wall.
#32
Holy crap! That's not something I want to hear! What grade of gas did you run in it? Was the timing set at stock? My 69 T-bird owner's manual states the need for 99.8 octane leaded fuel. I currently run 93 + octane boost + lead substitute additive. Theres no cheap tank of gas with these motors...
I think I might install a water injection system in the future to combat detonation. Distilled water is still cheaper than race fuel!
#33
#35
Today's system averages the 2 rating systems. Your 98 got lowered because the other system used lower numbers
Look here for explanation.
Octane rating - Wikipedia, the free encyclopedia
#36
#37
#38
Haa ha. No worries. My 400 LTD is dual fuel and I considered going dedicated LPG as I could have gone silly on compression (read up to 13-1, but stuck with about 9.5-1 so I could still use both. You have a lot cheaper gas (we call it petrol here in oz) while our propane is a cost effective substitute. When I saw you were considering water injection there would be a cost so that could be offset by the propane conversion. All good. merry xmas
#39
Save your money on the lead substitute. It just cost money and does nothing to improve the fuel.
#41
#42
#43
Yes why not. It's only money. Sometimes just removing the heads and doing a small job turns into a whole lot bigger. Been there done that. Ultimately happy with results but off the road for extended periods of time and empty wallet and lots of frustration when it was still going ok enough to enjoy it. I think Old sevillian is getting some fun running it at present. Oh and Sevillian, LPG still requires hardened valve seats for extended, appropriate service life. There is a supplier here in Aus that I can't remember at present (something like fuel star) that has a permanent fit into the fuel lines to minutely meter a lead replacement into the fuel. something like a couple of hundred but lasts for ages and the refills arent to bad. Maybe something to consider. I will look up for my own knowledge. Hope you had a good/safe xmas.
#45
^^I hope that's not the only piece of reasoning you have for claiming that lead substitute doesnt work.
I have no proof that it works and I have no proof that it doesn't. I'm not going to shell out the cash and dive in there on a 'maybe'!
If it ever gets hardened seats, that's going to be just one small part of a major top-end overhaul process.
