Stuck U-joint
Old Mar 24, 2004 | 12:19 PM
rbr651's Avatar
rbr651
Stuck U-joint
I've changed many a ujoints, however this one is stuck hard. The usual method I use is to grab a 6 inch C clamp, use a socket about the same size as the end cap on the U joint and turn until it comes loose. I bent up my clamp. Any suggestions?????
Old Mar 24, 2004 | 12:45 PM
wycowboy's Avatar
wycowboy
USe a bench vise , a big one . I had to do that to get mine out. I also had to put a long cheater bar on the end to get enough leverage J.
Old Mar 24, 2004 | 01:10 PM
rbr651's Avatar
rbr651
I see your also from WY, I'm in Cody where are you at?
Old Mar 24, 2004 | 01:34 PM
wycowboy's Avatar
wycowboy
I'm from sheridan, Born and raised
Old Mar 24, 2004 | 04:45 PM
z 97ford1's Avatar
z 97ford1
GO TO HARBOR FREIGHT AND BUY A UNIVERSAL JOINT PULLER, THEIR INEXPENSIVE AND HAS THE POWER TO REMOVE ANY U-JOINT.
petepetersen
Aug 9, 2009 05:35 PM
petepetersen
Aug 5, 2009 10:30 AM
F100DREAM
Sep 22, 2003 06:28 PM
