Transmission Swap
Old Mar 24, 2004 | 10:52 AM
44MAG_Gunslinger's Avatar
44MAG_Gunslinger
Transmission Swap
I have an 89 F150 4x4 with a 5.8. It currently has a badly slipping AOD transmission. (electronic shift I think) The C6 is alot easier to find and alot cheaper. Will this transmission bolt right in and work without any mods???? I.E. Transfer Case
Thanks ahead for any help
Old Mar 24, 2004 | 12:03 PM
boggerman's Avatar
boggerman
Physically they should interchange quite easily. You might run into some length differences, and shift linkage may be different as well, but you will have to research that as I don't have an AOD to look at here. Hope that helps.
Old Mar 24, 2004 | 05:21 PM
RTM's Avatar
RTM
I will be getting a parts bronco some time soon and may have the pieces you need. It has a C6 in it already.
Old Mar 24, 2004 | 07:08 PM
44MAG_Gunslinger
I also have a parts truck. It has a C6 in it now but it too is slipping. I am going to use it as a core. The biggest worry I am having is the computer getting confused or the transfer case not bolting in place.
Thanks for your replies
Old Mar 24, 2004 | 07:20 PM
44MAG_Gunslinger
I have another question. The C6 is a Vaccuum Controlled Tranny right? The AOD isn't is it?????
Old Mar 24, 2004 | 07:50 PM
RTM's Avatar
RTM
The AOD has a detent cable that controls the shifting so you shouldn't have aproblem with that and yest the C6 has a vacuum control. The transfer case should bolt right up.
What year parts truck do you have?
Old Mar 24, 2004 | 09:06 PM
44MAG_Gunslinger
Parts truck is a 1986. Bought it for 600. Already gonna get 300 back on the core.
Old Mar 25, 2004 | 04:27 AM
RTM's Avatar
RTM
I was just hoping you had an 89 parts truck. I need a few emission pieces.
