Door Panel Removal? Power Lock
Old Mar 24, 2004 | 10:50 AM
pbuzz3323's Avatar
pbuzz3323
Angry Door Panel Removal? Power Lock
2000 F350 CREW CAB...NEED TO REMOVE A PANEL ON BACK DOOR BUT DONT SEE A SINGLE SCREW? IS IT SNAPPED IN? ONE LOCK WONT GO UP OR DOWN AND WAS TOLD ITS A CLIP THAT PROBABLY CAME OFF? ITS A LARIAT LE MODEL
Old Mar 24, 2004 | 10:32 PM
cangim's Avatar
cangim
There should be a reflector on the lower panel. That peice will come out nicely with a flat blade screw driver. There is, I believe it is either an 8 or 10mm bolt. Remove the bolt. Lift the whole panel UP and then pull it off the door. Good luck
Old Mar 25, 2004 | 07:06 AM
f350xlt460's Avatar
f350xlt460
there are 2 screws
one behind the reflector and one behind/under the door lock/window switch panel.
Use a nut driver, remove the 2 screws the lift up and the panel is off.
Old Mar 25, 2004 | 03:57 PM
pbuzz3323's Avatar
pbuzz3323
Thanks Guys
Thanks...Got it!
