Front tank overflows
Old Mar 23, 2004 | 11:35 PM
Bikeitswift's Avatar
Bikeitswift
On my 88 F150, when I fill both tanks, my front one overflows when parked. The rear tank is apparently higher than the front. The gauge doesn't work on the back, either, but I see that's pretty common. I've been just filling the front, but it doesn't hold much gas. Anyone else had this problem??
Old Mar 24, 2004 | 02:23 AM
missouguy's Avatar
missouguy
Run a search on this topic, it has been discussed at length.
Frank
Old Mar 29, 2004 | 04:40 PM
Jack01's Avatar
Jack01
Ford's fix is to change both of the fuel pumps. this only applies if you have the dual hi pressure pumps only system. and not the low pressure duals with the booster on the rail. I fixed my dad's 87 f 150 by replacing the recirt valve or switching valve. some times it sticks open and fuel pumps into the front tank or migrats into the front from the rear.
hope this helps
oldmongo
16
Aug 8, 2012 11:07 PM
Dead Meat
Oct 6, 2009 12:52 PM
ac700wildcat
27
Nov 26, 2006 04:12 PM
joshwatts22
Mar 21, 2005 07:50 AM
gwuister
1983 - 2012 Ranger & B-Series
Feb 20, 2001 08:32 PM
